TEMA: menu in arkitool 2012
Re: menu in arkitool 2012 13 años 6 meses antes #2994
  • Gracias recibidas 32
Hi,
Go to Start+Run and type CMD.
In the window that opens type:
dir c:\xxx > D:\files.txt /s
(replace xxx for the directory of ARKITool 2012)
Send me the files.txt.
Última Edición: 13 años 6 meses antes por ARKITool.
Re: menu in arkitool 2012 13 años 6 meses antes #2995
  • person
The only txt file in Arkitool2012 folder is this
Archivo Adjunto:
Nombre del Archivo: Update.txt
Tamaño del Archivo: 1 KB
Re: menu in arkitool 2012 13 años 6 meses antes #2996
Hi,
The file to send is: d:\Files.txt (harddisk d:).
Re: menu in arkitool 2012 13 años 6 meses antes #2997
  • person
There's not such a file
Re: menu in arkitool 2012 13 años 6 meses antes #2998
  • person
Maybe because I uninstall the program few minutes ago
Re: menu in arkitool 2012 13 años 6 meses antes #2999
Hi,
Logically if you've uninstalled the program does not have anything.
What I need is to send me the directory structure and files you have after installing ARKITool 2012.
For that you have to do the following:
Tiempo de carga de la página: 0.109 segundos
