TEMA: ARKITool 12 crasches in BricsCAD 12
ARKITool 12 crasches in BricsCAD 12 13 años 7 meses antes #3668
  • Feanor01
Hello,
Yesterday I installed ARKITool 12 with BricsCAD v.12. I updated online after the installation, the program automatically loads ok into BricsCAD and all, but the installation seems very instable. It often crashes BricsCAD when I´m using standard ARKITool commands, for example opening a file or "sel-capturapol" etc.
No error messages or anything - it just hangs up/crashes. What could be the problem?
Regards
/David
Re: ARKITool 12 crasches in BricsCAD 12 13 años 7 meses antes #3669
Hello,
The program in Bricscad v12 is tested and working properly.
It may be a problem of RAM of PC. What revision of BricsCAD have (write "_Vernum" in BricsCAD)?
Re: ARKITool 12 crasches in BricsCAD 12 13 años 7 meses antes #3670
  • Feanor01
VERNUM = "12.2.17
I have 6,0 Gb RAM installed.
I can upgrade BricsCAD to v. 13 if that could solve anything?
Última Edición: 13 años 7 meses antes por Feanor01.
Re: ARKITool 12 crasches in BricsCAD 12 13 años 7 meses antes #3671
Hello,
The problem also occurs in a new drawing?
The problem always happens with the same drawing?
Run a software test of RAM memory.
The best would be to connect to your computer and see what the problem is. If you want, please to send an email to Esta dirección de correo electrónico está siendo protegida contra los robots de spam. Necesita tener JavaScript habilitado para poder verlo..
If memory is the problem, the problem will be the same with Bricscad v13.
Re: ARKITool 12 crasches in BricsCAD 12 13 años 7 meses antes #3672
  • Feanor01
Thank you for fast help, I appreciate much!
* Yes, problem can also occur in a new drawing
* No, different commands make the program crash, and sometimes they work. But the same command also have crashed the program two times in a row earlier...
If you would take the time to connect to my computer and see for your self I would appreciate it! I´ll send an email from gitech[at]bjorlin.fi
Re: ARKITool 12 crasches in BricsCAD 12 13 años 7 meses antes #3674
  • Feanor01
Thank´s a lot for solving my problem!
Great support!!!
Regards
/David
Tiempo de carga de la página: 0.106 segundos
