TEMA: menu in arkitool 2012
menu in arkitool 2012 14 años 1 mes antes #2960
  • person
I don't have arkitool2012 in menu bar in autocad 2013 and icons for topography are missing. I wanted to be in english, but it still in spanish . What can I do?
Re: menu in arkitool 2012 14 años 1 mes antes #2961
Hi,
First, to install "ARKItool 2012" asks the language (English have you chosen?)
If you are in Windows 7, Have you disabled UAC?
Only you are missing topography icons or any other?
Re: menu in arkitool 2012 14 años 1 mes antes #2973
  • person
I asked English and I have XP. I tried many times to install and uninstall the program, but with same result. I don't know if anyone have the problem with icons.
Thank you.
Re: menu in arkitool 2012 14 años 1 mes antes #2978
  • person
At every drawing opening ACAD give the mesage cannot find arkitool.cuix in ingles folder.
Re: menu in arkitool 2012 14 años 1 mes antes #2979
Hi,
Try make a directory named "Español" in the directory of "ARKITool 2012".
Tell me if you can make.
Re: menu in arkitool 2012 14 años 1 mes antes #2993
  • person
There is a folder with that name
Tiempo de carga de la página: 0.163 segundos
